pinephone keyboard + dock question
(01-25-2023, 04:49 PM)emsyr Wrote:
(01-24-2023, 11:48 AM)tuxcall Wrote: Hi!
i've recently gotten the pinephone keyboard
now i also have the dock that came with the pinephone.
The manual of the pinephone keyboard states to NOT charge through the pinephone usb port and only through  the keyboards usb charging port.
to use the dock you need to use the pinephone's usb and connect the charger to the dock. Which to me would be charging through the pinephone.
Which the manual warns against.
can you use the dock + the pinephone keyboard together or is this impossible?
I think you should charge through the keyboard's usb-c port and connect your dock in Pinephone's usb-c port to connect your peripheral devices.
In keyboard's manual it's written that:
Quote:You should charge the PinePhone and the keyboard only using the USB-C port on the keyboard. The keyboard’s USB-C port cannot be used for peripherals. The PinePhone’s USB-C port remains operational when mounted in the keyboard and can be used for data and peripherals.
I had already tried that (tried it again just now), but that didn't seem to work. no display on the hdmi and UI nor tweaks does not show a connected dock,
i have the suspicion the dock needs direct power to function
pinephone keyboard + dock question - by tuxcall - 01-24-2023, 11:48 AM
RE: pinephone keyboard + dock question - by emsyr - 01-25-2023, 04:49 PM
RE: pinephone keyboard + dock question - by tuxcall - 01-26-2023, 12:10 AM
RE: pinephone keyboard + dock question - by emsyr - 01-27-2023, 01:40 PM
RE: pinephone keyboard + dock question - by wigan - 02-03-2024, 02:53 PM
RE: pinephone keyboard + dock question - by wigan - 02-05-2024, 03:17 PM
  my pinephone melted norayr 6 816 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,077 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  quick question about mic Ferriah 3 319 03-23-2024, 02:11 PM
  various tricks to open the pinephone shengchieh 2 697 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 332 03-21-2024, 08:52 AM
Last Post: unrznbl
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,637 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,380 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 970 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,083 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,438 07-23-2023, 03:49 PM
Last Post: kb-zealot
