.CSV Without Nextcloud
(01-24-2023, 03:22 PM)food Wrote: I'm in Manjaro-ARM with Phosh with .csv file format. I may install a fresh operating system because Evolution isn't downloading nor is any other update.
Sorry, to be honest I did not read your question properly.
I don't know can you directly import with .csv format but I think Evolution will support vcard.
So maybe you find this helpful?
https://github.com/mridah/csv2vcf
If you don't want to use evolution there is phosh-contacts-importer app but it is in the aur so you need to enable aur first to install it.
And it is basicly the same app which repo I posted earlier on this thread Smile
.CSV Without Nextcloud - by food - 01-19-2023, 02:24 PM
RE: .CSV Without Nextcloud - by alaraajavamma - 01-19-2023, 02:45 PM
RE: .CSV Without Nextcloud - by Kevin Kofler - 01-19-2023, 03:20 PM
RE: .CSV Without Nextcloud - by food - 01-24-2023, 03:22 PM
RE: .CSV Without Nextcloud - by alaraajavamma - 01-24-2023, 03:51 PM
RE: .CSV Without Nextcloud - by zetabeta - 01-19-2023, 05:55 PM
  CardDAV / Nextcloud sync broken Uturn 0 1,428 06-15-2023, 12:41 AM
Last Post: Uturn
  nextcloud setup mruser1 2 3,045 12-05-2022, 03:22 AM
Last Post: alaraajavamma
  how to connect calindori to nextcloud? Uturn 2 3,490 06-26-2022, 02:09 AM
Last Post: wibble
  Nextcloud folder (WebDAV) not showing up in Portfolio PinePhoneUser 1 2,193 01-13-2022, 08:31 AM
Last Post: Uturn
  nextcloud contacts are duplicating Uturn 1 2,910 10-24-2021, 01:35 AM
Last Post: user641
  Plasma Mobile, Nextcloud account Uturn 1 2,929 03-05-2021, 09:14 AM
Last Post: Veraendert
