flipping frames bug and workaround
Not sure if this helps, but I noticed that this bug happens most often when:
- PinePhone is charging, but slowly (~0.5W, I use a battery case from another smartphone)
- Terminal is open
- I am typing something
Seems to happen less if PinePhone is not charging at all, or is plugged into a decent charger (as opposed to a battery case)
This has happened on:
- Mobian+phosh - fairly often
- pmOS+phosh - occasionally, but interestingly, the terminal mode (vol- + power 3 times) worked, and I was able to restart phoc from there
- pmOS+sxmo - once
flipping frames bug and workaround - by zetabeta - 01-01-2023, 04:05 AM
RE: flipping frames bug and workaround - by e1337 - 02-15-2023, 09:54 AM
RE: flipping frames bug and workaround - by Yaky - 03-27-2023, 07:11 PM
RE: flipping frames bug and workaround - by traut - 04-15-2023, 07:47 PM
RE: flipping frames bug and workaround - by aular - 12-21-2023, 08:07 AM
  poor call quality try flipping switch six D4rkh0rs3 0 1,360 05-12-2021, 12:09 PM
Last Post: D4rkh0rs3
  Importing vcf, country prefix problem workaround p1trson 3 4,442 12-02-2020, 09:29 AM
Last Post: cybercow
