07-19-2016, 03:34 PM
(07-17-2016, 08:07 PM)Ghost Wrote:(07-16-2016, 08:08 AM)bigben Wrote: Hi,
Newbie here and sorry for this stupid question.
I'm trying to burn sd card for my Pine64 2GB board, using Phoenix card utility V310 20130618. if I select any android or remix os image form the tool, an error window pop and complain there's "No script, try a new version image".
Should I burn the Phoenix image first with this Phoenix card utility, then use Win32 DiskImager to write the image I want to use?
Burn either a PhoenixCard image with PhoenixCard software, or a DD image with Win32DiskImager. You can't use an image meant for PhoenixCard on Win32DiskImager and vice-versa. Use either PhoenixCard or Win32DiskImager, with an appropriate OS image.
I think you may be trying to burn a DD image using PhoenixCard. Here are links to the latest Android and RemixOS images meant for PhoenixCard:
RemixOS:
http://files.pine64.org/os/remix/remix-v...ixCard.zip
Android:
http://files.pine64.org/os/android/andro...ixCard.zip
When trying to burn the disc image (with Phoenixcard) of the android image you linked to above, I format to normal (says successful) and then select Startup, select the image and select burn.
Says formating the card and gives error message in popup "Card Process failed !228"
It does so on two different Sandisk 32 GB Ultra Plus cards ...
Suggestions?
I get the message
