Audio Passthrough in SPMC Working
(07-12-2016, 11:21 PM)czechr08 Wrote: While I could not get Kodi to correctly reproduce AC3 audio via pass-through (cuts out for a fraction of a second every 5-10 seconds or so), I have been able to achieve correct AC3 audio reproduction with SPMC.  Playback of recorded mpeg-ts files has been great with no video sync issues or audio issues.  However, I am not getting great playback of live TV (via HDHomerun via tvheadend on an Odroid C1+).  I will need to explore that more, but more than likely it is related to my network/NAS setup.  The best playback experience of NAS mpeg-ts files has been through using Plex / MX player mashup.
My current settings / setup for SPMC is listed out below:
  • Android: 5.1.1 HDMI image release 20160505 64gb version non-rooted
  • SPMC build: SPMC 16.3-0 Git:2016-04-30-22df3d0-dirty
  • CAT 6 cables between as many devices as possible: Pine64 and Fast Ethernet (100/10) Switch which is then connected to my router (not sure if this made a difference as I did not methodically test it, but before CAT 6 I had lesser cables between some of these devices and I know at that time SPMC was not working correctly either)
  • HDMI from Pine64 to Marantz Receiver
SPMC Options:
Videos:
     Playback:
         Adjust display refresh rate: On start / stop
         Sync playback to display: Off
     Acceleration:
         Allow hardware acceleration -MediaCodec
System:
     Audio output:
         Audio output device: Android, RAW Passthrough
         Number of channels: 7.1
         Output Configuration: Fixed
         Limit sampling rate (kHz): 48.0
         Stereo upmix: On
         Maintain original volume on downmix: On
         Resample quality: High
         Enable audio DSP processing: Off
Hopefully someone can build off of this and continue to improve the Pine64 media experience.
I tried this setup with the last build (5.1.1 2016-10-19) and spmc 16.4.2 from the playstore. I don't have 5.1 surround. How did you do ? When i set "Output Configuration: Fixed", the passthrough option below is hidden. I only can set passthrough "on" with "Output Configuration: Optimized or Best match". When i set the passthrough option ON, i only get crashed sound. Did you tried that setup with updated software like mine since your post ?
Audio Passthrough in SPMC Working - by czechr08 - 07-12-2016, 11:21 PM
RE: Audio Passthrough in SPMC Working - by FoZo - 09-25-2016, 10:01 AM
RE: Audio Passthrough in SPMC Working - by FoZo - 10-01-2016, 02:02 AM
RE: Audio Passthrough in SPMC Working - by lbm34 - 11-02-2016, 03:41 PM
  3,5mm audio out not working MikkoL 9 14,389 11-22-2020, 06:42 AM
Last Post: Little_Johnny
  MTP Stopped Working miller08 0 2,408 12-24-2019, 02:42 AM
Last Post: miller08
  Android audio Danbrack 0 2,227 03-24-2018, 10:51 PM
Last Post: Danbrack
  Wiki version of Android 7.1 not working with touchscreen abba2566 3 5,275 02-28-2018, 08:02 AM
Last Post: wezzjm
  <•••> and no audio on my android is Help PoppaLeague 0 1,958 09-10-2017, 01:32 AM
Last Post: PoppaLeague
  Microphone / Audio In iammackinnon 4 6,241 04-24-2017, 07:03 AM
Last Post: kenjiru
  Android 6.0 TV analog audio Ophir 2 4,747 02-02-2017, 03:55 PM
Last Post: Ophir
  HDMI not working gubaguba 7 9,116 01-25-2017, 09:45 PM
Last Post: MakerLing81
  Netflix and Twitter no longer working Punkyclown 0 2,420 10-20-2016, 08:45 AM
Last Post: Punkyclown
  USB Audio? mesaxi 3 4,651 09-28-2016, 09:45 PM
Last Post: mikey0000
