Can you make reliable calls yet?
(08-14-2022, 02:51 PM)orbital Wrote: Hi,
What is the status of being able to make reliable calls on the PP and PPpro?
By reliable I mean:
- Calls go through
- Calls are not disconnected for no reason
- Audio levels are fine (sending and receiving).
- Both parties can hear each other.
Thanks.
Third day now and I made three calls so far. Barely usable until yesterday, and then I tried to use the mmcli to send a SMS (which worked), because the KDE Connect couldn't find a device (list empty) and neither could Telegram (spinning the busy circle forever). Now the signal strength stands at zero, the carrier's name is not displayed, and mmcli first showed the modem at position 1 (found it on 2 when I sent that message). Two minutes later it reports "no modems found".
I've found that there's some config file where the power control on a modem can be set so it doesn't get turned off, and opened that file with nano, but nano is unusable - the cursor stands at top of file, and the input method is the one for terminal, with just up and left arrow, no way to move the cursor to the end of line. Also doesn't recognize the ctrl+ characters, i.e. unusable. If there's a better editor available, I'd like to know.
I managed to ssh into the phone from my PC and that at least speeds up the attempts.
So... my supply of questions is near endless, but first
- how do I wake up the modem(s) and keep it awake
- how do I make KDE connect fill its list of devices
Can you make reliable calls yet? - by orbital - 08-14-2022, 02:51 PM
RE: Can you make reliable calls yet? - by orbital - 08-14-2022, 05:13 PM
RE: Can you make reliable calls yet? - by wibble - 08-15-2022, 12:11 AM
RE: Can you make reliable calls yet? - by Chief - 08-15-2022, 04:58 PM
RE: Can you make reliable calls yet? - by better - 10-11-2022, 10:52 PM
RE: Can you make reliable calls yet? - by Eugo - 08-15-2022, 03:22 AM
RE: Can you make reliable calls yet? - by Eugo - 08-15-2022, 07:18 AM
RE: Can you make reliable calls yet? - by Eugo - 08-16-2022, 04:34 AM
RE: Can you make reliable calls yet? - by Eugo - 08-17-2022, 10:50 AM
RE: Can you make reliable calls yet? - by Eugo - 08-18-2022, 02:10 AM
RE: Can you make reliable calls yet? - by cone99 - 08-17-2022, 05:19 AM
RE: Can you make reliable calls yet? - by cone99 - 08-17-2022, 07:54 AM
RE: Can you make reliable calls yet? - by cone99 - 08-18-2022, 08:49 AM
RE: Can you make reliable calls yet? - by Eugo - 08-18-2022, 11:07 AM
RE: Can you make reliable calls yet? - by Eugo - 08-19-2022, 03:11 AM
RE: Can you make reliable calls yet? - by Eugo - 08-28-2022, 11:11 AM
RE: Can you make reliable calls yet? - by vortex - 08-28-2022, 03:33 PM
  4G VoLTE calls confirmed working with carrier x dcinoz 15 12,267 03-09-2024, 11:38 PM
Last Post: dcinoz
  Buetooth handsfree calls on PinPhone alabasha 7 2,000 08-18-2023, 09:29 AM
  pinephone no longer receiving calls or texts jyoung 3 1,909 07-16-2023, 10:05 PM
Last Post: jyoung
  Reliable OS? FOSSagent0 3 1,376 05-16-2023, 05:47 AM
Last Post: Eugo
  Handsfree bluetooth calls conifera 0 867 02-28-2023, 02:07 PM
Last Post: conifera
  Calls, SMS benedikt55 1 1,039 12-13-2022, 10:42 AM
Last Post: treebeard
  phone calls are enough for now wehape2bees 2 2,158 07-30-2022, 06:06 PM
Last Post: zetabeta
  Mute function on calls? scrwbigtek 0 775 05-30-2022, 12:52 PM
Last Post: scrwbigtek
  Developers wanted to make out of the PinePhone a Respiratory Monitor Peter Gamma 0 1,000 03-20-2022, 10:58 AM
Last Post: Peter Gamma
  Problem with incoming calls (w/o ModemManager/Ofono) jlucas 10 7,816 08-09-2021, 05:38 PM
Last Post: mouffa
