Problematic WiFi Adaptor
(07-30-2022, 04:06 PM)natomon01 Wrote: Hi Everyone,
Has anybody had problem getting WiFi to work consistently? I can connect to my home router and use it for about 5 minutes, but then it seems to error out and disconnect. This presents as a signal-strength kind of issue, but that seems ridiculous when the phone is sitting within 4 ft of the router and none of my other devices (in other rooms) are having problems. Though, I was able to connect to a guest WiFi in a public area and things seemed to work consistently.
Does anybody have any ideas? Could my little NetGear router be bumping my device off for some reason? If any body else has had this problem I'd love to hear if you solved it.
Please always tell which distro, which kernel, tow-boot, open modem firmware etc..
After 5 minutes PPP goes to deep sleep and turns off wifi as well, maybe this is the case you are facing.
Problematic WiFi Adaptor - by natomon01 - 07-30-2022, 04:06 PM
RE: Problematic WiFi Adaptor - by magdesign - 08-01-2022, 02:33 PM
RE: Problematic WiFi Adaptor - by natomon01 - 08-07-2022, 12:54 AM
  Pinephone pro packet injection for internal wifi chipset covar 1 873 08-13-2023, 04:40 AM
Last Post: fxc
