Flashing to the eMMC
(06-16-2022, 06:52 AM)prairie33 Wrote: Hello, I'm trying to flash Manjaro ARM Phosh to /dev/mmcblk as described on the Flashing to the eMMC section of the wiki.
However, when I run the dd command an error is returned: error writing to '/dev/mmcblk2': No space left on device
1803+0 records in
1802+0 records out
1890381824 bytes (1.9 GB, 1.8 GiB) copied
Using the manjaro-arm-phosh image file.
I've run
sudo pacman -Sc
but still no space left. Any thoughts about how to install? I've tried gnome-disk-utility but it doesn't show emmc.
Did a sudo fdisk -l and the mmcblk2 does not display. Thanks!
The issue is that you're writing to a file named "mmcblk2" on the microSD card here, instead on the eMMC. Type "lsblk" to list all devices, you will probably see that the eMMC isn't listed there. The second issue here is that the RE button was held too long. The RE button disconnects the eMMC and when you disconnect the eMMC at boot for too long it doesn't get initialized.
To summarize: hold the RE button for shorter, check to which device you're writing to with "lsblk".
Flashing to the eMMC - by prairie33 - 06-16-2022, 06:52 AM
RE: Flashing to the eMMC - by fxc - 06-18-2022, 11:00 AM
RE: Flashing to the eMMC - by prairie33 - 06-18-2022, 12:55 PM
RE: Flashing to the eMMC - by prairie33 - 06-18-2022, 01:17 PM
RE: Flashing to the eMMC - by fxc - 06-18-2022, 04:49 PM
  DeviceNotReady After flashing modem firmware nekonosuke 4 5,023 02-13-2024, 11:36 PM
Last Post: nekonosuke
Bug "bricked" my eMMC tigerbalm69 4 4,713 05-09-2023, 11:09 AM
Last Post: tigerbalm69
  Flash Pinephone Pro image from SD card to eMMC? jcun4128 9 13,308 03-11-2022, 09:09 AM
Last Post: fxc
  Guide: Recovering from not being able to boot to eMMC or working sdcard Ulfnic 2 5,407 02-02-2022, 10:29 PM
Last Post: bcnaz
  Explorer vs Dev edition - flashing? brb78 0 2,142 12-09-2021, 02:25 PM
Last Post: brb78
