Possibly dysfunctional as a cell phone
(02-13-2022, 08:00 AM)tckosvic Wrote:
(02-13-2022, 02:53 AM)lllsondowlll Wrote:
(02-12-2022, 08:59 PM)tckosvic Wrote: I am finding that if the PPP is off the charger (as in your pocket when you go out) it turns off after about 45 minutes and does not answer calls.  If you activate it with the start button, it still wakes up (not a reboot/restart from cold) and does answer calls.  To me this makes the PPP dysfunctional as to be a usable cell phone if you can't reliably get a call after 45 minutes off the tether.
I am running tests calling PPP with android phone.  It looks like about 45 minutes from a full charge before it goes dead and stops answering after being off charger.  Still at 70% or so battery.  I will continue to test.  Manjaro-phosh system.
Are others seeing the same thing or is this just my phone?   How long can you have the PPP off charger and still receive a call?  What if you go out with 70% battery, 50% battery?
thanks,     tom kosvic
PPP is still early. Distros are still working out suspend, drivers, and battery optimization with the new chipset.
What you are experiencing is a partial suspend in deep sleep that is failing to keep the modem active when the rest of the phone is in low power mode. This was the same thing that needed work for the original Pinephone and was working correctly after a couple of months. Give the Pinephone Pro some time. This isn't a daily driver yet and has to go through some of the stages the original Pinephone did in terms of optimization.
If you don't want it to suspend you can turn that off in the settings. Or set suspend never. Won't be good for battery life, but atleast you can take calls until it's fixed
If this was found in the PP, why wasn't the fix included in development plan for the new chip for the PPP.  Is suspend a distro setting or a desktop setting, or a system software (kernel) setting?  In development, you're supposed to incorporate found fixes in the next version and not release the new version until important fixes are made.
I will find the suspend setting and test with it enabled and disabled.
tom kosvic
I think you are misunderstanding. The Pinephone Pro software is still under development. It is stated as so on the purchase page of Pine64 website. There will be bugs It's being worked on.
Disable suspend from settings for now if you want it to reliability wake and not have to cold boot it every 15 minutes.
RE: Possibly dysfunctional as a cell phone - by lllsondowlll - 02-13-2022, 05:03 PM
Question Phone call with the pinephone pro dfs 5 4,295 02-10-2024, 09:54 PM
  PPP used with smart phone gaming fan. DaForest 3 870 11-19-2023, 05:17 AM
Last Post: crocspot
  Is the pine phone usable as a daily driver now? gautamb11 18 4,535 10-27-2023, 12:46 AM
Last Post: gregb49
  Pine Phone Pro: Mobian+plasma mobile GabrieleMax 2 1,572 04-30-2023, 05:03 AM
Last Post: diederik
  pine phone pro won't start robb777 2 1,407 01-25-2023, 04:38 PM
Last Post: emsyr
  Current State of PIne Phone Pro kmsgli 40 26,002 12-23-2022, 06:44 PM
Last Post: Simon Belmont
  Was the Pine Phone Pro you got from DHL new? theForce 3 2,054 10-31-2022, 04:26 PM
Last Post: fxc
  Internet is not working on Pine Pro phone caroljames972022 0 883 09-16-2022, 06:25 AM
Last Post: caroljames972022
  Loud echo on receiving phone when called TheRealThor 3 2,144 08-09-2022, 10:09 AM
Last Post: tckosvic
  Phone not reading sim For_lack_of_a_better_name 6 4,272 06-09-2022, 01:00 PM
Last Post: daveman1010220
