SMS app
(02-07-2022, 05:39 AM)Frost1776 Wrote:
(02-07-2022, 02:23 AM)lllsondowlll Wrote: I'm running Manjaro Phosh with Mint sim on PPP.
I go into settings, enable mobile data, and set my APN:
APN: Wholesale
Then open up terminal and run "sudo pacman -S mmsd-tng"
This enables MMS
Then reboot the phone so that it is working, open up chatty and and enter the APN settings for MMS under preferences
http://wholesale.mmsmvno.com/mms/wapenc
More info on Mint's APN settings here:
https://www.mintmobile.com/setup/android/
I'm not sure which version of Manjaro you are running, but I assume entering the correct APN settings should work for Manjaro plasma similarly. I can send and receive MMS and group chats fine as well as browse the internet over 4G LTE
I'm running the stock Manjaro for now, I've tried most of the distros out now and prefer this in the early stages of all of them.
I will try what you said when I get off today.
My main thing is finding an app that works, when I'm in phone book and clock send message, it say no device to connect to. Is there a fix for that?
I'm not sure, I hopped away from the Manjaro Plasma to Manjaro Phosh since I had the phone for stability and functionality. Manjaro plasma is still a bit buggy and unpolished. I can send and receive calls, text messages, group chats, and pictures via MMS on Manjaro Phosh. For whatever questions you have for Plasma I have no idea.
SMS app - by Frost1776 - 02-06-2022, 09:15 PM
RE: SMS app - by lllsondowlll - 02-07-2022, 02:23 AM
RE: SMS app - by Frost1776 - 02-07-2022, 05:39 AM
RE: SMS app - by lllsondowlll - 02-07-2022, 11:48 AM
