compiler wev
(02-04-2022, 11:55 AM)oihantto64 Wrote: To adapt the pinephone keyboard, I will need to use the equivalent of xev for wayland ie wev, or the version available on AUR is not suitable for arm64. Is it difficult to adapt the pkgbuild to compile compatible with aarch64?
Most of the time, if you just change the `arch=('x86_64')` or whatever it is to `arch=('aarch64')`, it will work. Those are usually close to the top of the PKGBUILD.
compiler wev - by oihantto64 - 02-04-2022, 11:55 AM
RE: compiler wev - by ragreenburg - 02-04-2022, 12:08 PM
RE: compiler wev - by oihantto64 - 02-05-2022, 01:58 AM
RE: compiler wev - by ragreenburg - 02-05-2022, 02:04 AM
