01-31-2022, 07:14 PM
(01-31-2022, 01:24 PM)rmpek Wrote: hi,Are you wanting to boot from the sd card ?
i am having issues with my PPP (EE) - i can sometimes get it to start (from emmc), and then things are fine, but usually i dont get anything. no led, no buzz, nothing. i have now tried pressing "re" ... the exact sequence isnt clear to me. should i also press power? or simply press "re" while connecting via USB? dmesg on the machine i am connecting it to stays silent, no usb devices appear. also - battery in or out? does it make a difference?
the cable is fine, i tested it with another phone, and i have also swapped cables - and i also have charge the ppp on it before.
one thing i did notice was that the sd card slot sounded weird when i first inserted a card - i also have the original PP, and it did not have this issue. i would desribe the sound as "scratchy" - does anyone else have this issues?
what could i try? i would really like to keep playing with it.
.rm
with a charged battery --> insert the flashed sd card --> when powering up --> hold the power button for 5 or 6 seconds, instead of the standard 2 seconds.
My brand new Pro started from the sd card on the first try using that method.
LINUX = CHOICES
**BCnAZ**
Donate to $upport
your favorite OS Team
**BCnAZ**
Donate to $upport
