charging indicator
(01-31-2022, 04:54 AM)bcnaz Wrote:
(01-30-2022, 07:08 PM)nristen Wrote: Update:
I followed the new additional instructions added on the wiki: https://wiki.pine64.org/wiki/PinePhone_P...structions
located in the section in blue beginning with:
If the battery is fully drained U-Boot might fail...
After letting it charge for about 6 hours, I am now getting a response however it still fails to fully boot.
After hitting the power button for two seconds to turn it on, a spinning indicator comes on for about 2 seconds then it goes to a blank screen with a tiny pointer that I can move around the screen by touching the display.  If I hit the power button again it goes back to the spinning icon for a few seconds before the screen goes black.
I am wondering if the boot failure is the result of the failure to update the system when I first got the phone when I tried to update using the discover app and then tried using pacman -Syu.
Does anyone else have any knowledge of what the black screen with the tiny pointer indicates?
I have also tried to boot with an sd card by holding down the power button for 5 - 8 seconds but I get the same results.
If the boot is broken on your eMMC,   perhaps the sd card will boot with the short 2 second power button press ?
Just a thought.
Curious :  what OS did you put on your sd card ?
I have tried the SD card with Manjaro ARM plasma for pinephone pro (20220129 and 20220130) - I have been unable to get the phone to boot from either.  I have tried holding the power button down for 5 to 6 seconds and holding down the reset button while hitting the power button.
I have ordered the serial to USB cable and the external battery charger but expect those to take several weeks to arrive.
I will also probably try to make a video showing what I have attempted to see if that provides any further insight into what I might be doing wrong.
charging indicator - by nristen - 01-28-2022, 02:15 PM
RE: charging indicator - by FrozenPine - 01-28-2022, 02:48 PM
RE: charging indicator - by nristen - 01-28-2022, 04:11 PM
RE: charging indicator - by timonoj - 01-29-2022, 12:46 AM
RE: charging indicator - by thismarty - 01-30-2022, 12:29 PM
RE: charging indicator - by captainmorgan - 01-30-2022, 01:58 PM
RE: charging indicator - by thismarty - 01-30-2022, 03:00 PM
RE: charging indicator - by frankt - 01-30-2022, 06:29 PM
RE: charging indicator - by nristen - 01-30-2022, 07:08 PM
RE: charging indicator - by bcnaz - 01-31-2022, 04:54 AM
RE: charging indicator - by nristen - 01-31-2022, 06:05 PM
RE: charging indicator - by bcnaz - 01-31-2022, 07:20 PM
RE: charging indicator - by nristen - 02-01-2022, 09:04 AM
RE: charging indicator - by bcnaz - 02-02-2022, 05:28 AM
RE: charging indicator - by phelion - 02-02-2022, 09:01 AM
RE: charging indicator - by nristen - 02-03-2022, 01:31 PM
RE: charging indicator - by phelion - 02-03-2022, 04:36 PM
  PinePhonePro turns on when connecting usb charging cable xt0 5 1,042 10-10-2023, 12:01 PM
Last Post: zetabeta
  New out of box phone, vibrates and solid red light on charging StuckInTheCloud 1 909 03-24-2023, 03:12 PM
Last Post: fxc
Question Battery not charging when run down to 0. iwm 2 1,877 02-08-2022, 10:45 AM
Last Post: mburns
  USB to PC connection not charging PPP tckosvic 0 891 02-01-2022, 05:40 PM
Last Post: tckosvic
