Pin login fails when unplugged
(12-23-2021, 08:02 AM)slomobile Wrote: Seems to work normally if plugged in.  When running on battery(any state of charge) the pin screen is only up very briefly unless you are constantly touching the screen.  On the rare case the phone does unlock, the screen very quickly goes black and locks again.
Seems to be an old bug when setting the screen timeout value wrote incorrect and very short time values to configuration file. So the updates do not help. You have to either manually correct the value or even better - flash the latest software image Wink
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
Pin login fails when unplugged - by slomobile - 12-23-2021, 08:02 AM
RE: Pin login fails when unplugged - by acrux - 12-23-2021, 09:37 AM
RE: Pin login fails when unplugged - by slomobile - 12-23-2021, 10:53 PM
Sad Phone stuck in a login loop jpaulbiss 1 2,208 09-10-2021, 07:19 AM
Last Post: acrux
  Safety issues with numeric login and sudo passord Line 5 4,325 07-05-2021, 12:17 PM
Last Post: zetabeta
  modem and login/reset issues dhawk 1 2,205 06-23-2021, 05:04 PM
Last Post: 33YN2
