11-26-2021, 03:26 AM
(11-25-2021, 07:21 PM)Zebulon Walton Wrote: Should I also delete the 5.13 kernel to free up more space on /boot? On a regular desktop system if something happens to the newest kernel I can select an older one to boot up on (if present) via the grub menu. I'm not sure if it's possible to do that on the Pinephone.
I don't know, but you can check how much space you have left on your partitions with:
df -h
I noticed that after this update my phone has trouble going to sleep, which decreases battery life. Dmesg:
PM: Some devices failed to suspend, or early wake event detected
OOM killer enabled.
Restarting tasks ... done.
PM: suspend exit
PM: suspend entry (s2idle)
Filesystems sync: 0.087 seconds
Freezing user space processes ... (elapsed 0.005 seconds) done.
OOM killer disabled.
Freezing remaining freezable tasks ... (elapsed 0.002 seconds) done.
printk: Suspending console(s) (use no_console_suspend to debug)
sunxi-mmc 1c0f000.mmc: data error, sending stop command
sunxi-mmc 1c0f000.mmc: send stop command failed
mmc0: error -110 reading status reg of PM func
PM: dpm_run_callback(): mmc_bus_suspend+0x0/0x74 returns -110
mmcblk mmc0:aaaa: PM: failed to suspend async: error -110
OOM killer enabled.
PM: suspend exit
