Pinephone Pro vs Pinephone Parts
To quote from here (https://www.pine64.org/pinephonepro/) -- scroll down to the FAQ:
I am a PinePhone owner – will I be able to upgrade it by installing a PinePhone Pro mainboard?
Probably not. While the PinePhone Pro’s mainboard will fit the PinePhone, the chassis, IPS display panel, cameras, the daughterboard, and thermal dissipation systems are all different. For instance, the PinePhone Pro’s cameras will not fit into the PinePhone chassis and are electrically incompatible with PinePhone Pro’s mainboard. Software enablement would also be required to drive the original PinePhone’s components (such as the LCD) using the PinePhone Pro’s mainboard. Thermal dissipation is another important consideration, as the higher heat output may not be trivial to overcome in the original PinePhone’s chassis.
and
How repairable is the PinePhone Pro?
Just as the original PinePhone, the PinePhone Pro is built to be user repairable and we will offer spare parts in the Pine Store. The store’s selection will include all parts that frequently break if the device is dropped (the screen, back case and mid section) as well as all electronic components, including the mainboard.
hope that helps
Pinephone Pro vs Pinephone Parts - by luney - 10-15-2021, 06:55 PM
RE: Pinephone Pro vs Pinephone Parts - by lacriz - 10-15-2021, 07:26 PM
RE: Pinephone Pro vs Pinephone Parts - by luney - 10-15-2021, 07:47 PM
RE: Pinephone Pro vs Pinephone Parts - by vajak - 10-17-2021, 06:41 AM
RE: Pinephone Pro vs Pinephone Parts - by poVoq - 10-17-2021, 05:51 AM
RE: Pinephone Pro vs Pinephone Parts - by lot378 - 10-17-2021, 10:06 AM
RE: Pinephone Pro vs Pinephone Parts - by ypd - 10-17-2021, 02:13 PM
RE: Pinephone Pro vs Pinephone Parts - by lot378 - 10-17-2021, 03:13 PM
RE: Pinephone Pro vs Pinephone Parts - by lot378 - 10-18-2021, 08:43 PM
RE: Pinephone Pro vs Pinephone Parts - by bcnaz - 10-19-2021, 06:16 PM
RE: Pinephone Pro vs Pinephone Parts - by linmob - 10-27-2021, 08:44 AM
  Where to find spare parts? mdk 2 152 05-09-2024, 02:12 PM
Last Post: mdk
  my pinephone melted norayr 6 1,031 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,145 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 769 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 414 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,967 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,911 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,473 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 1,070 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,332 08-23-2023, 03:25 AM
Last Post: Kali
