First cable for Euler Bus power done!
(10-03-2016, 10:25 PM)Ghost Wrote:
(10-03-2016, 08:37 PM)Bluphire Wrote:
(10-03-2016, 07:05 PM)pfeerick Wrote:
(10-03-2016, 12:30 PM)Bluphire Wrote: What does this do?
The MicroUSB connector has a max rating of 1.8A, and a lot of MicroUSB leads are pretty wimpy (wires too thin, poor conductivity contacts) , and will not provide the Pine64 with the necessary power when it is loaded up, leading to file corruption, random brownouts, reboots, etc. This cable plugs into the euler bus, and powers the pine64 via the power pins there.
And the USB Plugs into....?
An appropriately rated power supply (with female USB connector).
Ideally 1.8A or higher? How many amps is too many amps?
RE: First cable for Euler Bus power done! - by Bluphire - 10-03-2016, 11:00 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,122 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,621 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,541 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,402 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,864 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,391 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,709 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,978 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,438 01-07-2017, 11:59 PM
Last Post: aegrotatio
  Correct Voltage For Powering From Euler?? thisrestricted 7 11,341 10-18-2016, 06:49 PM
Last Post: veronicasmithen03
