First cable for Euler Bus power done!
Hi g_t_j!
The connectors are : http://www.digikey.com/product-detail/en...ND/5246541
I would not use these connectors in a free-hanging application or without some sort of heat shrink stabilizing them, for free hanging applications I'd pick something from these options :
http://www.digikey.com/product-search/en...ageSize=25
For the USB-A end I used : http://www.digikey.com/product-detail/en...ND/1007894
The Braiding is 1/4" : http://www.digikey.com/product-search/en...30-1055-ND
The heat shrink I used is : http://www.digikey.com/product-search/en...53x038b-nd
I hope this helps! Smile
AVL
RE: First cable for Euler Bus power done! - by AVL2016 - 06-25-2016, 07:47 AM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,118 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,615 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,541 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,396 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,854 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,391 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,707 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,977 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,435 01-07-2017, 11:59 PM
Last Post: aegrotatio
  Correct Voltage For Powering From Euler?? thisrestricted 7 11,332 10-18-2016, 06:49 PM
Last Post: veronicasmithen03
