Is there a better calendar app?
(08-17-2021, 10:33 AM)ragreenburg Wrote:
(08-17-2021, 10:09 AM)swiley Wrote: The best Linux calendar I've found is the Emacs Diary. It uses a superset of the classic "calendar" syntax and integrates with appointments for notifications. Since it's a human written file it's easy to keep in git with all your other stuff.
Can that give notifications though? I tried using Org Mode to make a bunch of to-do's and put them on deadlines but I couldn't get notifications to work in the background. Basically to me a calendar just needs to be able to say "Hey, it is 8:00am, don't forget to do blank".
I've never had it generate desktop notifications as I use an overlapping window manager on my phone so I can usually see the emacs window. This SE post shows someone calling notify-send from a hook though: https://emacs.stackexchange.com/question...eea37d80fe
Is there a better calendar app? - by ragreenburg - 08-16-2021, 02:37 PM
RE: Is there a better calendar app? - by acrux - 08-17-2021, 02:32 AM
RE: Is there a better calendar app? - by swiley - 08-17-2021, 10:09 AM
RE: Is there a better calendar app? - by swiley - 08-17-2021, 10:39 AM
  Nextcloud Calendar and Contacts mark1250 3 1,485 12-29-2022, 07:27 PM
Last Post: mark1250
  Synchronizing: How do you sync / synchronize Calendar and Contacts with your desktop? Anna 15 14,559 11-04-2021, 03:54 AM
Last Post: Maus
  Thunderbird for Calendar and Email rp3 2 4,016 01-12-2021, 06:02 AM
Last Post: rp3
Lightbulb Calendar and syncthing cybercow 1 2,520 11-17-2020, 10:43 AM
Last Post: Lousy Fisherman
