first use - asking for passcode which i never set - help!
(07-27-2021, 04:58 AM)CrawfordLV Wrote: I got a PinePhone  "Manjaro" a few months ago... ...Now the screen comes up asking for a "passcode" number which i never set in the first place.
If you have such "old" PinePhone, then the default password was "123456". Newer Manjaro Plasma Mobile comes with the fisttime setup wizard during what the password is set. Not sure about Manjaro Phosh.
However - it would be easier if you make a fresh start with recent operating system build. Manjaro Pinephone Images are here:
https://github.com/manjaro-pinephone
RE: first use - asking for passcode which i never set - help! - by acrux - 07-27-2021, 08:30 AM
Question Infinite loop: passcode entry -> lock-screen, repeat danimations 3 3,160 07-12-2021, 08:21 PM
Last Post: danimations
  disable passcode lock screen? notpod 2 3,021 12-17-2020, 11:51 AM
Last Post: notpod
  Passcode to login to Manjaro on Pinephone livanti21 4 12,098 10-01-2020, 07:29 AM
Last Post: Doodenheimer
