Three Quick Questions...
(06-05-2021, 07:57 PM)Magnus Wrote: Hello techlords,
I've been running SXMO on pmOS as my daily driver for 3+ weeks. I am a noob and non-programmer. So, bear with me. I would like to accomplish 3 goals:
  1. How can I autoload SD card at boot (the OS runs from emmc)? From there, I plan to use midnight commander (mc) to play some tunes.
  2. How do I copy received text messages? Sometimes, I receive a HTML link and would like to cut&copy it.
  3. How can you add programs to the app menu (Thunar adds but MC does not, etc..)?
Thank you.
I don't believe that postmarket has an APK for midnight commander. If your goal is music though, then what you really want is CMUS and there is an APK. In terminal type, "sudo apk add cmus". It will download and install. Search on the internet how to use CMUS. I love using CMUS on SXMO. Just remember that in SXMO, you will have to change to headphones in the OS to play on headphones.
I will leave number 2 to someone else.
For number 3, some apps will appear on reboot. CMUS will show up for example. Otherwise, you should check out the contribute section of the SXMO website.https://sr.ht/~mil/Sxmo/
Three Quick Questions... - by Magnus - 06-05-2021, 07:57 PM
RE: Three Quick Questions... - by luney - 06-06-2021, 02:40 PM
RE: Three Quick Questions... - by Magnus - 06-08-2021, 05:45 PM
RE: Three Quick Questions... - by Magnus - 07-29-2021, 03:37 PM
RE: Three Quick Questions... - by Magnus - 08-02-2021, 01:07 PM
