Manjaro phosh annoying problems and a bit of usage experience
Hi there, i have encountered a couple of annoying things about using manjaro phosh after the latest update:
1) Sometimes modem goes down completely. I don't know how to reproduce that, but sometimes modem module shuts down completely, and calls application says that there is no calling device at all. Naturally, internet also goes down. Rebooting does fix it, but a couple of times it caught me when i had to give a call or quickly search for something on the internet.
2) Audio is kinda glitchy now. Sometimes audio just stops coming out through both speaker and earphones jack. For example, when i listen to music with Audacious player it stops playing after some time (3-5 minutes). Most curious, this time depends on the track i listen to (and moon phase, i suppose). This issue is also related to alarm, which is much worse. Thankfully, i did not have anything urgent when i overslept because of the alarm problem. Sound returns right after i press unlock button (just have to turn on the screen, even without entering the passcode). Technically it keeps playing music/sound, but into nowhere. However, not all applicatins have that problem: freetube works nicely when i listen to any videos in podcast mode with locked screen.
Please write if you have encountered similar problems and if you have solved them.
A bit of usage experience:
In spite of technical problems (like mentioned above) i love that phone. Unfortunately, i can't use it as my primary phone yet, but it is always my number 2.
What it can:
1. Browse internet. Firefox works nice here. Unfortunately, ui of extensions is broken, but the rest is fine
2. Watch youtube. I use freetube application with legacy video format, which gives me acceptable ~480p video.
3. Use messangers. Telegram works fine, fractal and NeoChat launch and look good, but did not use them yet. Pretty sure it will run any messanger you would like to install.
4. Listen to music. Mentioned above problem is annoying, but is not fatal. Furthermore, there must be player that can avoid that problem.
5. Call. Calling is allright, both incoming and outcoming (if modem did not go down, but this is temporary, i hope)
6. Use navigtion. Standart maps application works normally.
7. Programming. I wrote a couple of python scripts using vim and launched a couple of self-written java console utilities. Did not find a proper IDE yet, but it has jdk, gcc, python and tons of other development tools. When a physical keyboard finally comes out it would be excellent development tool to use "on a go"
What it can't:
1. Run android apps. I've seen messages on forum that anbox is working, but mine doesn't. Probably because i use beta5 and update it with pacman -Syu. I will try to fix that later, but now i have to write diploma.
2. Take photo and record video. Technically, megapixels app can take photos, but preview is much worse than the actual photo. It also works very slow, which is critical if you want to catch a moment.
Manjaro phosh annoying problems and a bit of usage experience - by Nick_dnepr - 06-02-2021, 02:55 AM
  Manjaro: Settings doesnt open nbh 0 617 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,633 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,660 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 836 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,936 03-02-2023, 07:25 PM
  Backup and Home Screen Tinkering on Phosh jakfish 0 883 02-24-2023, 12:56 PM
Last Post: jakfish
  Can't install Manjaro thorensjubilee 1 1,058 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 5,039 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,612 11-22-2022, 05:00 PM
Last Post: Chief
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,091 10-10-2022, 12:53 PM
Last Post: alaraajavamma
