Questions about filming video with the Pinephone
(05-30-2021, 09:30 AM)MirceaKitsune Wrote:
(05-28-2021, 05:32 PM)vortex Wrote: Yes to 1080p @ 30 fps. The datasheet says so.
60 fps probably not. The datasheet showed the fps increasing steadily as the resolution decreased downward. You would need to dive deep into the data sheet to find what the maximum frame rate at 1080p is. It might be a bit higher than 30 fps, but it is almost certainly less than 45 fps.
Thanks, that clarifies what I wanted to know. So at least the same video quality as a Samsung Galaxy S3 should be assured, that's great! Just curious: Is there a hardcoded limit in the camera against trying to film at 60 FPS, or can you still try it but if the hardware can't handle the data flow you get laggy footage?
(05-28-2021, 05:32 PM)vortex Wrote: Megapixels is installed by default on many distros for the PinePhone. It is a GUI app. It is still pretty minimal, and can't take video last I checked. It can take pictures with both cameras on the PinePhone, and does the post processing to do color correction and that sort of thing. Note that such post processing is not done for the preview.
I see. So I need a separate app to film video then, other than the one used to take photos? What is a good one to install if so? GUI based obviously... even I'm not that nerdy to type a console command whenever I walk across something I want to take a film of Big Grin
As far as I know there is no app for taking videos on the Pinephone so far. The feature is on the to do list for Megapixels, but I have no idea how far away that is. I've read somewhere here of using a screen recorder (wf-recorder probably?) to capture the preview footage from Megapixels. It's an ugly workaround with bad image quality, but maybe the easiest way for now to record at least some kind of video if it actually works.
RE: Questions about filming video with the Pinephone - by kqlnut - 05-31-2021, 02:09 AM
  my pinephone melted norayr 6 953 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,119 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 737 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 381 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,890 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,416 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,435 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 1,038 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,192 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,501 07-23-2023, 03:49 PM
Last Post: kb-zealot
