modem no carrier message
yes you can do many things with ofono, every service has got some configuration files which in the case of Plasma should be updated manually as shown in the manual, Phosh probably uses scripts and configures both the modem and the network interface automatically, I will research it in order to port it to Plasma, the ability to work with D-Bus seems to be indispensable for every Pinephone user
Plasma should be considered experimental, if you use Phosh you will notice the difference, everything just works, Firefox has been ported from android and accepts add-ons, excellent terminal emulator and many other features
the guide is very extensive and covers most the features Pinephone has, very helpful and comprehensive for anyone
now I will explore the17-distro image, I am mostly interested in SailfishOS
http://xnux.eu/p-boot-demo/
modem no carrier message - by Rainer - 05-08-2021, 07:34 AM
RE: modem no carrier message - by mouffa - 05-18-2021, 06:33 AM
RE: modem no carrier message - by Rainer - 05-18-2021, 08:10 AM
RE: modem no carrier message - by mouffa - 05-18-2021, 10:25 AM
RE: modem no carrier message - by mouffa - 05-20-2021, 04:53 AM
RE: modem no carrier message - by mouffa - 05-20-2021, 06:56 AM
RE: modem no carrier message - by Rainer - 05-20-2021, 09:43 AM
RE: modem no carrier message - by mouffa - 05-20-2021, 10:48 AM
RE: modem no carrier message - by mouffa - 05-22-2021, 04:33 AM
RE: modem no carrier message - by Rainer - 05-22-2021, 12:06 PM
RE: modem no carrier message - by mouffa - 05-22-2021, 02:59 PM
RE: modem no carrier message - by Rainer - 05-24-2021, 08:13 AM
RE: modem no carrier message - by mouffa - 05-24-2021, 10:47 AM
RE: modem no carrier message - by mouffa - 05-25-2021, 12:36 PM
RE: modem no carrier message - by mouffa - 05-26-2021, 12:20 PM
RE: modem no carrier message - by mouffa - 05-27-2021, 06:02 AM
  Supported Carrier and Modem Bands NachoMomma 4 1,585 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 542 02-17-2024, 04:15 PM
Last Post: vortex
Bug PinePhone modem keeps "disappearing" Kevin Kofler 14 5,657 03-22-2023, 05:28 PM
  modem not working michelinux 0 931 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 4,238 02-15-2023, 11:17 AM
Last Post: fxc
  PinePhone carrier support in Hungary notramo 7 2,691 12-14-2022, 12:18 PM
Last Post: notramo
  firmware udate Quectel EG25-G modem alwi 7 5,393 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 2,873 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 4,136 06-13-2022, 04:12 AM
Last Post: zetabeta
  Modem Hardware bad? Not ready for 5g?? linux76 8 4,717 05-31-2022, 06:41 PM
Last Post: SwordfishII
