05-05-2021, 07:27 AM
(05-05-2021, 01:41 AM)barray Wrote: > 7. After updates i powered down and charged for >8 hrs, battery at 60%.
> 8. After 30 min use battery at 16% and case is warm
As far as I'm concerned that hardware is still a work in progress. You could likely greatly increase battery by turning off any radio not in use (Bluetooth, WiFi, Cellular, etc).
Hi B,
I had quickly read on the forum that charging was/is a function of the software, so I expected it to be wonky. I'll try turning off wifi and bluetooth.
As I go thru the forum I'm sure I will come to realize other other tricks.
Q. Are there any tutorials? Or any good info that you know of for on getting started? etc. etc. I have inserted my sims and my Mint network is not immediately recognized. I need to hunt around to access/read/write the sims too. Any thoughts?
Should I create new posts as I go thru my own start up process or continue on this one? Any thoughts?
