Hooks and userscripts: POST 'EM!
Hook-seller! I need your STRONGEST hooks and userscripts!
I'll start.
Surf gesture so that back and enter go back and forward in history.
#!/bin/sh
# $HOME/.config/sxmo/hooks/gesture
case $1 in
        "surf")
                if [ $2 = "back" ]; then
                        xdotool key ctrl+h & exit 0
                elif [ $2 = "enter" ]; then
                        xdotool key ctrl+l & exit 0
                else
                        exit 1
                fi
        *) exit 1
esac
Ring hook that checks if the number is a contact. If so, it will ring, if not, it won't! This cuts down on being annoyed by robo-callers. It also checks if the file $HOME/.config/sxmo/silent exists. If so, it won't ring. I stole the main bits of the ring/pickup scripts from someone here (if it's you, sound off and thanks!) but added the contact/silent checking.
#!/usr/bin/env sh
# $HOME/.config/sxmo/hooks/ring
NUMBER="$1"
CONTACT=$(sxmo_contacts.sh --all |
        grep "$NUMBER"
SILENT=$HOME/.config/sxmo/silent
incallmonitor() {
        CALLRINGING=$(mmcli -m "$(modem_n)" --voice-list-calls)
        echo $CALLRINGING
                if [[ "$CALLRINGING" == "No calls were found" ]]; then
                    exit 1
        fi
modem_n() {
        MODEMS="$(mmcli -L)"
        echo "$MODEMS" | grep -qoE 'Modem\/([0-9]+)' || finish "Couldn't find modem - is your modem enabled?"
        echo "$MODEMS" | grep -oE 'Modem\/([0-9]+)' | cut -d'/' -f2
if [ -n "$CONTACT" ]; then
        sxmo_audioout.sh Speaker
        amixer sset 'Line Out' 100%
        if [ ! -f $SILENT ]; then
                mpv --no-resume-playback /home/mo/Music/char.opus
        fi
        while true; do
                sxmo_vibratepine 1000
                notify-send $1
                incallmonitor "$1"
        done
else
        while true; do
                notify-send $1
                incallmonitor "$1"
        done
fi
#!/bin/sh
# $HOME/.config/sxmo/hooks/pickup
ID=$(ps -ef|grep ring|grep -v grep|perl -ne '$_=~ m/^ *(.*) mo.*/;print $1')
kill -9 $ID
pkill mpv
sxmo_audioout.sh
#!/usr/bin/env sh
# $HOME/.config/sxmo/userscripts/silent
if [ -e $SILENT ]; then
        rm $SILENT && notify-send "Not Silent"
else
        touch $SILENT && notify-send "Silent"
fi
I'm not the greatest shell scripter, but with just a little bit here and there, sxmo gets comfier and comfier. It is now "legs go numb on the toilet while looking at memes on the pinephone" worthy. I'm also looking for some apps hook examples if you got 'em! I can't seem to make mine work without breaking something.
Hooks and userscripts: POST 'EM! - by MungFuSensei - 01-27-2021, 09:38 PM
Tongue how to manage userscripts Uturn 7 4,971 08-01-2022, 02:33 PM
Last Post: TRS-80
