I can't create the microsd
(06-07-2016, 10:31 AM)Arkhanjel Wrote: Hi, I can't create the microsd with Phoenix Card, when I choose the *.img file the program says: "Script NOT found. Please use new version image". I try with Android, Xubuntu and Remix. Thanks.
You cannot create Linux images with Phoenix Card. I also suspect that you tried burning dd images - hence the error.
This is the Remix OS and Android images you need for Phoenix Card. You need win32imager (granted you are on windows) to burn a linux image.
Remember to set 'Startup! in Phoenix Card.
If you have further problems let me know on here or in chat (see sig)
[edit] oh, and you can burn the images you have already downloaded using win32imager - if you got ones that fit your SD card size
I can't create the microsd - by Arkhanjel - 06-07-2016, 10:31 AM
RE: I can't create the microsd - by Luke - 06-07-2016, 10:40 AM
RE: I can't create the microsd - by jl_678 - 06-08-2016, 10:24 AM
RE: I can't create the microsd - by Ghost - 06-08-2016, 12:10 PM
  MicroSD, Which one should I buy? ronaldolcc 1 3,410 03-20-2017, 04:46 PM
Last Post: Luke
  Samsung EVO+ microSD simplexdan 7 7,803 03-02-2017, 03:31 AM
Last Post: pfeerick
