USB file transfer?
(02-24-2021, 12:30 PM)marcih Wrote: Mobian used to have a daemon that would let you transfer files over MTP. Try to see if the "umtp-responder" package is available for Manjaro and install it. You can also submit a feature request in the Manjaro issue tracker (all the graphical environments have a separate one).
Apparently warrior linux style is via scp over ssh e.g.
scp ~/*.txt kde@<ip address>:/home/kde/
You can invert source and destination to copy from Pinephone to laptop/desktop from which you ssh.
You need to be able to ssh e.g. kde@<ip_address> for scp to work, of course. Google or man for scp info.
USB file transfer? - by SameExpert - 01-07-2021, 07:50 AM
RE: USB file transfer? - by marcih - 02-24-2021, 12:30 PM
RE: USB file transfer? - by dcinoz - 02-24-2021, 04:40 PM
RE: USB file transfer? - by SameExpert - 05-04-2021, 09:26 AM
  How do you install VPN so you can set up a config file, tor, signal and disk encrypt? temp0rary 5 3,944 05-30-2021, 08:14 PM
Last Post: temp0rary
  file transfer Rainer 3 3,039 05-10-2021, 08:53 PM
Last Post: Rainer
  Which config file contains the APN specification field? Harambest 6 5,147 02-16-2021, 05:55 PM
Last Post: vkraven
  FIle Browser popup when sing Nemo/Calendar on Beta 4 nimji 5 5,215 01-28-2021, 03:29 PM
Last Post: kern707
