Constant freezes or kernel panics
(12-22-2020, 08:09 AM)data_kraken Wrote:
(12-21-2020, 01:43 PM)LMM Wrote:
(12-21-2020, 08:34 AM)data_kraken Wrote:
(12-21-2020, 04:39 AM)diizzy Wrote: Can't really help but are you running a recent kernel (5.9 or 5.10) and using a recent version of u-boot?
Yes, Kernel is 5.9 and since it was a fresh install with the most recent image offered for download I'd say everything else is recent too.
Is there a max capacity for the adapter ? 8To is a big disk.
Never seen one mentioned anywhere. And 8TB really isn't all that much nowadays when you can buy 20TB drives. But in any case the setup worked at first and the problem existed even without the drives so I assume their size isn't the problem.
Also some more details on the OS:
[Image: screenfetch.png]
what about your power supply ?
why not using the ayufan image ?
RE: Constant freezes or kernel panics - by diizzy - 12-21-2020, 04:39 AM
RE: Constant freezes or kernel panics - by LMM - 12-21-2020, 01:43 PM
RE: Constant freezes or kernel panics - by LMM - 12-22-2020, 02:02 PM
RE: Constant freezes or kernel panics - by LMM - 12-23-2020, 11:17 AM
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 5,710 10-20-2020, 10:52 AM
Last Post: GreyLinux
  kernel for NAS chengjianwen 2 3,681 03-21-2019, 09:18 PM
Last Post: onfire4g05
