Proximity sensor rubber pad gasket replacement
(12-12-2020, 08:50 AM)puffchumpy Wrote: My braveheart pinephone never had the small gasket that covers the proximity sensor. This causes the proximity sensor to provide bad readings to phosh and blanks the screen. Now after making a phosh based image I edit the udev rules to disable the proximity sensor. I was hoping the replacement mainboard would include the proximity sensor cover, but it did not. Though an uncommon problem I'm not the only one to have this issue based on the various messages on the forum.
I tried the fix shown by RWXYZ, but I'm having trouble getting the tiny pieces aligned correctly. See https://forum.pine64.org/showthread.php?...=proximity
Does anyone have a 3D printable fix for the proximity and light sensor gasket? I might be able to get a friend to print it some versions.
Any other thoughts on potential fixes? I'm missing the part so don't know exactly what is needed.
I just had my phones in pieces and took some very amateur photos of mine in the jaws of my micrometer, yell if you really are clutching at straws and can cope with awful pics!
Actually considering I let the magic smoke out of 1 of my USB daughter boards could loan you 1 for a couple of weeks if you are in the UK? (Actually the antenna male came off the board with the cable when trying to unplug the antenna cable :-(  )
RE: Proximity sensor rubber pad gasket replacement - by dukla2000 - 12-13-2020, 02:35 PM
  Screen Replacement Instructions erikkugel 5 9,548 02-24-2025, 06:55 AM
Last Post: anonymous
  Replacement screen disconnects after back frame is screwed on robthebold 4 5,102 10-12-2023, 01:03 PM
Last Post: robthebold
  Microphone replacement SocialNetworkingWasAMistake 1 3,306 08-05-2022, 03:16 PM
Last Post: calinb
  Screen replacement Csanderson0313 4 6,106 01-10-2022, 09:26 PM
Last Post: Csanderson0313
  Replacement Loud Speaker kmsgli 18 25,462 11-01-2021, 12:25 PM
Last Post: mickclark430
  LCD panel replacement instructions mob 2 3,980 09-13-2021, 05:11 PM
Last Post: mob
  Battery replacement alternative sax1960 7 10,698 08-29-2021, 07:03 AM
Last Post: bcnaz
  inner earpiece speaker replacement dcinoz 4 7,701 07-24-2021, 04:37 AM
Last Post: dcinoz
  Screen or motherboard replacement? Static Face 2 4,913 06-08-2021, 12:57 AM
Last Post: Static Face
  Mainboard replacement does not boot/charge boarf 2 4,657 05-02-2021, 10:47 AM
Last Post: boarf
