Mapping Euler bus DC in and 5v DC out pins
Amazing!
Thanks so much both of you guys!
I did finally locate the 2 pins providing 5V based on the diagram you provided and have successfully powered a 5V fan but was a bit reluctant to try anything on the Euler bus. There is no room for mistakes there as you can easily fry the board...
With that image, however, I'm on safe ground! I will make a USB-to-2 pin cable and will try to power the board!
Cheers!
RE: Mapping Euler bus DC in and 5v DC out pins - by g_t_j - 06-03-2016, 12:59 PM
  +LTS/SOPINE +PINEBOOK configuring Euler Bus pin generate interrupt RANJITT76 0 2,441 01-10-2019, 02:45 AM
Last Post: RANJITT76
  connect lipo battery to euler bus jodybrown99 19 25,751 09-14-2016, 11:51 PM
Last Post: pfeerick
  System LED mounting option using header pins and remote LED for use in the ABS case MarkHaysHarris777 1 3,973 08-28-2016, 07:02 PM
Last Post: pfeerick
  Testing the GPIO pins shockr 7 9,450 08-10-2016, 05:30 PM
Last Post: MarkHaysHarris777
Question What exactly is a Euler Bus? Ghost 10 37,617 05-06-2016, 06:49 PM
  Euler Bus hrh1818 4 13,874 01-29-2016, 01:56 PM
