Screen Game changer: gsettings set sm.puri.phoc scale-to-fit true
(11-26-2020, 11:55 PM)nbh Wrote:
(11-26-2020, 09:54 PM)dallytaur Wrote: I found changing the UI scale from 2 to1.5 helps a ton
Where do you change the UI scale?   How did you find it or is part of overall configuration items?
Using sudo, edit:
/usr/share/phosh/phoc.ini
and change the top value from 2 to 1.5 then run:
sudo systemctl restart phosh
to view the changes. I personally found the scaling to be sufficient at 2.
RE: Screen Game changer: gsettings set sm.puri.phoc scale-to-fit true - by arcanemachine - 11-27-2020, 12:27 AM
  screen brightness Uturn 1 766 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 699 07-07-2023, 09:38 AM
Last Post: Uturn
  Backup and Home Screen Tinkering on Phosh jakfish 0 890 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen timeout makes alarm and timer unusable... Eugo 9 4,185 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,983 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 7,370 09-05-2022, 03:50 PM
Last Post: christev1
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 1,019 07-04-2022, 11:42 AM
Last Post: tuxmain
  How to return to "home screen" hiddenpotato 7 6,442 03-05-2022, 06:21 AM
Last Post: dcinoz
  Manjaro Welcome screen landscape JohanB89 2 2,243 11-12-2021, 01:13 AM
Last Post: acrux
  KDE Plasma Mobile screen scaling Uturn 1 1,863 10-29-2021, 06:59 AM
Last Post: Uturn
