How hard to replace screen?
#23
(01-14-2021, 01:26 PM)lusoman Wrote:
(11-25-2020, 10:58 PM)Zebulon Walton Wrote: Thanks, I've got the phone apart but am not sure how to transfer the USB-C side board to the new screen housing. (I started a new thread asking about that but no responses there yet.) It has a piece that looks like a copper mesh possibly glued to the housing and I'm not sure yet how to remove it without damage. Here's a photo of the part from the Pine store:
[Image: PinePhone-USB-C-Board-1-1-300x300.jpg]
I tried to replace this this morning, and destroyed this part. The flex connection from the PCB to the other part is fragile.
After ripping it, I experimented with getting the speaker out, and detaching the rest.
I did the following:
1. loosen the wires attached to the speaker just "north" of the speaker itself.
2. use a small flat-bladed screwdriver (1 mm) to gently pry up the speaker at the southeast (4.30pm).
3. When the speaker is loose, gradually list the thin flex from the case.
4. grab a corner of the large square part of the flex with forceps, and lift it carefully.
5. When you get close to the narrow flex on the right SLOW down and be very, very careful and detach the flex.
I'm confident I wouldn't balls it up if I had to do it again, if I used this approach.
Good luck!
Sorry for the delay in follow-up, but I did get it all working OK. Not sure where to point you, but if I were you I would just reseat everything.
How hard to replace screen? - by Zebulon Walton - 11-13-2020, 08:10 PM
RE: How hard to replace screen? - by hiimtye - 11-14-2020, 09:35 PM
RE: How hard to replace screen? - by wibble - 11-15-2020, 06:25 AM
RE: How hard to replace screen? - by wibble - 11-16-2020, 07:16 AM
RE: How hard to replace screen? - by lusoman - 01-14-2021, 01:26 PM
RE: How hard to replace screen? - by israel - 04-14-2021, 09:48 AM
RE: How hard to replace screen? - by lusoman - 04-14-2021, 10:17 AM
RE: How hard to replace screen? - by israel - 04-14-2021, 10:25 AM
RE: How hard to replace screen? - by lusoman - 04-14-2021, 10:54 AM
RE: How hard to replace screen? - by wibble - 11-26-2020, 10:47 AM
RE: How hard to replace screen? - by p1trson - 11-26-2020, 02:12 PM
RE: How hard to replace screen? - by wibble - 11-27-2020, 07:44 AM
RE: How hard to replace screen? - by wibble - 11-27-2020, 06:48 AM
RE: How hard to replace screen? - by p1trson - 11-27-2020, 11:54 AM
RE: How hard to replace screen? - by wibble - 11-29-2020, 07:08 AM
RE: How hard to replace screen? - by wibble - 11-30-2020, 01:12 PM
RE: How hard to replace screen? - by israel - 04-14-2021, 03:17 PM
RE: How hard to replace screen? - by israel - 04-14-2021, 04:25 PM
RE: How hard to replace screen? - by calinb - 10-28-2021, 12:00 AM
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 384 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,355 10-12-2023, 01:03 PM
Last Post: robthebold
  Screen dying already? marcih 153 145,949 02-23-2023, 04:14 AM
Last Post: Shatur
  Screen Replacement Instructions erikkugel 4 3,159 09-07-2022, 11:04 PM
Last Post: RTP
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,654 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 1,740 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 4,025 03-08-2022, 12:25 PM
Last Post: jopple
  pinephone screen Uturn 2 2,287 01-14-2022, 01:15 AM
Last Post: Uturn
  Screen replacement Csanderson0313 4 3,233 01-10-2022, 09:26 PM
Last Post: Csanderson0313
  Hacking project: Replace lcd with third party displays. holycow 6 4,531 12-26-2021, 04:49 AM
Last Post: barray
