What works. What doesn't work.
#26
(11-13-2020, 12:36 PM)liewyec Wrote: I used etcher to flash the card, but i have 32GB card and it uses only like 3GB of space. The flashing script uses the entire card for the system. It sometimeo reboots, and freezes similar way as it happens to you, but after reboot it works. Anyway i disabled pin on sim card for now a I can send, receive messages, and mobile data works, i did not try calls yet, but i tried to update to version 3.4.0.24 and today it is somehow broken. Yesterday it work fine and today it fails for some reason.
I had a similar situation but for me Sailfish just stopped charging so it may as well be broken. Also worth noting, I don't think MMS is working on Sailfish.
RE: What works. What doesn't work. - by LinAdmin2 - 11-03-2020, 11:47 AM
RE: What works. What doesn't work. - by josekar - 11-04-2020, 04:46 PM
RE: What works. What doesn't work. - by stemplet - 11-06-2020, 01:14 PM
RE: What works. What doesn't work. - by clover - 11-08-2020, 04:56 PM
RE: What works. What doesn't work. - by W64 - 11-09-2020, 10:36 AM
RE: What works. What doesn't work. - by stemplet - 11-09-2020, 05:02 PM
RE: What works. What doesn't work. - by W64 - 11-09-2020, 05:20 PM
RE: What works. What doesn't work. - by stemplet - 11-09-2020, 07:14 PM
RE: What works. What doesn't work. - by W64 - 11-09-2020, 08:11 PM
RE: What works. What doesn't work. - by clover - 11-11-2020, 12:02 AM
RE: What works. What doesn't work. - by as400 - 11-11-2020, 03:28 AM
RE: What works. What doesn't work. - by stemplet - 11-11-2020, 09:42 AM
RE: What works. What doesn't work. - by liewyec - 11-12-2020, 01:09 AM
RE: What works. What doesn't work. - by sfb - 11-12-2020, 11:17 AM
RE: What works. What doesn't work. - by liewyec - 11-12-2020, 12:57 PM
RE: What works. What doesn't work. - by LinAdmin2 - 11-12-2020, 01:10 PM
RE: What works. What doesn't work. - by liewyec - 11-12-2020, 01:30 PM
RE: What works. What doesn't work. - by LinAdmin2 - 11-13-2020, 11:32 AM
RE: What works. What doesn't work. - by liewyec - 11-13-2020, 12:36 PM
RE: What works. What doesn't work. - by ragreenburg - 11-16-2020, 09:36 AM
RE: What works. What doesn't work. - by liewyec - 11-18-2020, 02:01 AM
  When mobile data works calls don't with Sailfish OS albafrati 0 1,910 06-25-2024, 09:28 AM
Last Post: albafrati
