All the Manjaro Builds!
I tried the lomiri Alpha 1 and it is super snappy, which I expected as that was my experience with UBPorts, but it's a hopelessly closed system. there doesn't look to be any work to even port over libertine to get X11 apps working, and there's only like 8 apps (weather crashes, and the calendar doesn't even get added to the menu. I haven't found any other method of finding apps that work in lomiri, other than a pacman -Ss lomiri
installing an X11 app (for instance, Firefox) results in some weird split window thing where one window is the title of the app, and the other window is titled /usr/lib/appname and both are empty.
this might be a viable solution if there were more apps, and/or Anbox worked in it.
All the Manjaro Builds! - by Cree - 09-22-2020, 09:59 AM
RE: All the Manjaro Builds! - by Potts - 09-23-2020, 10:38 AM
RE: All the Manjaro Builds! - by hiimtye - 09-24-2020, 04:54 PM
RE: All the Manjaro Builds! - by hiimtye - 09-30-2020, 05:33 PM
RE: All the Manjaro Builds! - by Cree - 10-01-2020, 08:35 AM
RE: All the Manjaro Builds! - by DrewTechs - 10-04-2020, 10:49 PM
RE: All the Manjaro Builds! - by preflex - 10-06-2020, 04:28 AM
RE: All the Manjaro Builds! - by bcnaz - 09-30-2020, 09:35 PM
RE: All the Manjaro Builds! - by zetabeta - 10-01-2020, 12:56 AM
RE: All the Manjaro Builds! - by hiimtye - 10-02-2020, 02:06 AM
RE: All the Manjaro Builds! - by LinAdmin2 - 10-02-2020, 06:36 AM
RE: All the Manjaro Builds! - by firefox-58 - 10-02-2020, 08:25 AM
RE: All the Manjaro Builds! - by cefre00 - 10-09-2020, 05:33 PM
  Manjaro: Settings doesnt open nbh 0 615 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,630 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,657 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 836 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,924 03-02-2023, 07:25 PM
  Can't install Manjaro thorensjubilee 1 1,058 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 5,036 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,612 11-22-2022, 05:00 PM
Last Post: Chief
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,090 10-10-2022, 12:53 PM
Last Post: alaraajavamma
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 2,543 09-05-2022, 03:42 PM
Last Post: nroth
