WiFi signal weak
(09-27-2020, 08:07 PM)kelbot Wrote: Thank you for the report. I've tried Mobian and have poor signal as well. This entry in the wiki is the only thing keeping me from thinking I'm crazy right now Big Grin.
I guess I will have to open it up and see if something is loose.
You are welcome! Again, reception is good on my tab, going outside the house or to the second floor where router is at first floor is no problem. Good luck and keep us up to date!
WiFi signal weak - by kelbot - 09-17-2020, 02:40 PM
RE: WiFi signal weak - by kelbot - 09-27-2020, 10:49 AM
RE: WiFi signal weak - by guenther - 09-27-2020, 04:32 PM
RE: WiFi signal weak - by kelbot - 09-27-2020, 08:07 PM
RE: WiFi signal weak - by guenther - 09-28-2020, 06:10 AM
RE: WiFi signal weak - by kelbot - 10-06-2020, 09:20 PM
RE: WiFi signal weak - by guenther - 10-07-2020, 02:40 AM
RE: WiFi signal weak - by Algot - 10-08-2020, 08:11 AM
RE: WiFi signal weak - by Jeffersoniantoo - 10-10-2020, 03:24 PM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 8,020 02-28-2024, 05:03 AM
Last Post: Surehand53
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,205 07-14-2023, 03:09 AM
Last Post: gregb49
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 2,354 06-06-2023, 05:26 PM
Last Post: fxc
  Wifi adapter not found after update failed jojuma 0 643 01-22-2023, 05:15 PM
Last Post: jojuma
  kernel crash on wifi initialization javier.pb 0 2,087 12-30-2020, 08:01 AM
Last Post: javier.pb
