Segfault with GCC in Armbian [Solved].
This is a followup post to to confirm that the Rock64 board that was experiencing segmentation faults with the default 786 MHz memory clock on Armbian is now stable with the uboot-initialized 333 MHz setting.
On a selection of computational benchmarks performance is about 77 percent of the original setting;
for compilations with gcc more than 80 percent of the original performance is retained with the added advantage that the system doesn't crash and the compiler doesn't create segmentation faults.
I understand, but did not verify, that setting the memory clocks to 333 MHz has a noticeable affect on video playback.
As far as I'm concerned this problem is solved and I'll try to mark it as such. Although one out of the two Rock64 single-board computers I have required this configuration change, based on posts appearing on this forum, my suspicion is a much less than 50 percent--perhaps closer to 10 or 20 percent--of systems in use actually exhibit this problem.
Even so, I would favor a note on the wiki support page for the Rock64 explaining how to work around system instability by reducing the DDR RAM memory clock.
______________________
Optics 4 birding
RE: One works the other doesn't. - by ejolson - 08-31-2020, 01:48 PM
RE: One works the other doesn't. - by Rocklobster - 08-31-2020, 08:54 PM
RE: One works the other doesn't. - by ejolson - 09-01-2020, 10:02 PM
RE: One works the other doesn't. - by t4_4t - 08-31-2020, 09:45 PM
RE: One works the other doesn't. - by ejolson - 09-02-2020, 09:11 AM
RE: One works the other doesn't. - by ejolson - 09-02-2020, 02:09 PM
RE: One works the other doesn't. - by tomarm - 09-01-2020, 12:30 AM
RE: One works the other doesn't. - by ejolson - 09-04-2020, 08:58 PM
RE: Segfault with GCC in Armbian [Solved]. - by stelabentley - 07-07-2021, 10:16 AM
  Rock64 No Audio - Solved wbecks 12 38,038 08-13-2021, 01:23 PM
Last Post: blakeadam
  Rock64-4gb,Armbian Debian Stretch: Plex, Radarr, NZBGet and Sickchill WOW Baracuda2 1 3,832 02-27-2019, 03:34 PM
Last Post: Luke
  [SOLVED] stuck at emmc dr_dre 10 16,732 04-29-2018, 05:10 PM
Last Post: pfeerick
  Solved - When did you order your Rock64 rhille 5 8,887 08-25-2017, 07:17 AM
Last Post: rhille
