How to compile the kernel?
Seems to me, that you're doing it right. When installed the .deb pinephone-u-boot-install should be run (a script under /usr/sbin I believe).
What got me started was this.
I have used a slightly different make command (setting env vars), maybe that's the difference?
Good luck!
How to compile the kernel? - by Boern - 08-04-2020, 12:24 AM
RE: How to compile the kernel? - by devrtz - 08-04-2020, 06:00 AM
RE: How to compile the kernel? - by nas - 08-04-2020, 07:48 AM
RE: How to compile the kernel? - by Boern - 08-04-2020, 08:38 AM
Big Grin An early xmas present: 6.1 kernel treebeard 28 9,972 07-18-2023, 03:14 AM
Last Post: gischpelino
  how to disable ipv6 at kernel level with towboot? vusra 2 919 07-09-2023, 01:25 AM
Last Post: vusra
  Stability problems with 6.1 kernel Zebulon Walton 9 2,617 05-12-2023, 08:09 AM
Last Post: zetabeta
  Kernel 5.15 Zebulon Walton 10 6,283 11-27-2021, 01:10 PM
Last Post: LibrePhoneUser
  Mobian kernel upgrade user641 4 3,852 11-10-2021, 01:22 PM
Last Post: user641
  kernel upgrade user641 2 2,548 09-13-2021, 08:26 AM
Last Post: user641
  [Solved] How to get a kernel newer than 5.10 on Mobian ? gab 0 1,387 08-26-2021, 04:08 PM
Last Post: gab
  Kernel fault on adapter connect pinephone.damiano 0 1,083 08-15-2021, 04:25 AM
Last Post: pinephone.damiano
  Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build? LibrePhoneUser 3 4,020 01-17-2021, 12:44 PM
  Phone doesn't boot after latest kernel update Boern 12 13,502 08-06-2020, 11:34 AM
Last Post: Boern
