RAM cooling, thermal pads, paste, and height difference
(08-06-2020, 08:03 AM)Gienek Wrote: I have considered the same question, and finally measured temperature of the RAMs. They are significantly cooler than the CPU. Even during intensive RAM-load test.
I'm interested; can you share the details of your test?
What load did you apply to the RAM? Was the load constant? For how long had the peak load temperature remained constant before you took your final measurement? What were the temperature readings before and during the load test? What was the ambient temperature? How did you measure temperatures?
RE: RAM cooling, thermal pads, paste, and height difference - by foresto - 08-06-2020, 11:42 AM
  M-size and length of standoffs used in acrylic case. Heatsink height. Tigger 3 5,423 06-13-2018, 04:47 AM
Last Post: pfeerick
