Add contacts with VCF files
(07-17-2020, 01:34 PM)Bouc Wrote: Hi, is there an easy way to import contacts from a vcf file?
I can't use simcard (different format) and I don't want a Google account.
Edit to solve:
From https://wiki.mobian-project.org
Import contacts from VCF file
Syncevolution has been removed from upstream Debian, in the meantime it is straightforward to import contacts from a VCF file via Evolution tooling. First install evolution:
sudo apt install evolution
Before you import the file you will need to set scale-to-fit for Evolution on, otherwise the import dialog page is unusable.
scale-to-fit Evolution on
After this I opened the .vcf file via the Files app, it auto-launched the import dialoug. After importing I removed the Evolution app, this step is optional:
sudo apt remove evolution
sudo apt autoremove
This worked for me in Manjaro as well, but the terminal commands are slightly different:
To install evolution:
sudo pacman -S evolution
scale-to-fit evolution on
To import contacts:
Open your *.vcf file from 'nemo' on your desktop
Follow the dialogue in evolution.
To remove evolution:
sudo pacman -R evolution
If it isn't broken, take it apart and fix it.
Add contacts with VCF files - by Bouc - 07-17-2020, 01:34 PM
RE: Add contacts with VCF files - by clover - 07-17-2020, 04:45 PM
RE: Add contacts with VCF files - by Bouc - 07-19-2020, 12:44 PM
RE: Add contacts with VCF files - by Bouc - 07-19-2020, 03:39 PM
RE: Add contacts with VCF files - by jjs - 07-19-2020, 09:32 PM
RE: Add contacts with VCF files - by Bouc - 07-20-2020, 01:24 PM
RE: Add contacts with VCF files - by jjs - 07-21-2020, 10:08 AM
RE: Add contacts with VCF files - by Bouc - 07-21-2020, 10:37 AM
RE: Add contacts with VCF files - by Bouc - 07-21-2020, 01:17 PM
RE: Add contacts with VCF files - by Be. - 05-01-2021, 03:22 PM
RE: Add contacts with VCF files - by voidmain - 10-16-2020, 08:02 AM
RE: Add contacts with VCF files - by MonCon - 11-03-2020, 05:09 PM
RE: Add contacts with VCF files - by Gribouille - 11-20-2020, 10:34 AM
Question How to Save Read Only Files, Questions on Location lovepine88 8 475 Yesterday, 06:08 PM
Last Post: ryo
  Synchronizing: How do you sync / synchronize Calendar and Contacts with your desktop? Anna 12 1,211 04-22-2021, 02:42 AM
Last Post: Anna
  gnome-contacts not showing call nor sms button cafe 2 462 02-11-2021, 01:31 AM
Last Post: cafe
  how to import contacts from sim cards cybercow 7 1,802 12-06-2020, 01:14 PM
Last Post: cybercow
