USB-C Dock and HDMI, revison 1.2 (Modded)
(08-03-2020, 04:37 PM)hetp Wrote: # git might not be installed by default - on debian use 'apt install git' to install it, on manjaro use 'pacman -Syu git'
git clone https://megous.com/git/linux-firmware
cd linux-firmware/
sudo cp anx7688-fw.bin /lib/firmware/
# you must be root for the next bit as sudo does not work
su -
# control d to logout of root (or type exit and hit enter) - never stay logged in as root (use sudo where possible)
At the moment getting the hdmi to work is very hit and miss. So keep plugging away. I can't give you any hints because I haven't found any pattern yet.
I wrote a long detailed post but the format keeps getting messed up. So, here is a trimmed short version.
This post https://forum.pine64.org/showthread.php?tid=10907 provided me information on being able to use both the Pinephone screen and external screen at the same time. Assumed hardware fix and anx firmware has been flashed. Install wlr-randr. Connect dock, cables, keyboard, etc.
Have Pinephone screen on, then "wlr-randr --output HDMI-A-1 --on", "wlr-randr --output HDMI-A-1 --mode 1280x720@50Hz". If there are noticeable graphical issues restart Phosh "sudo systemctl restart phosh.service", then set the external resolution again ""wlr-randr --output HDMI-A-1 --mode 1280x720@50Hz".
RE: USB-C Dock and HDMI, revison 1.2 (Modded) - by Ersatz - 08-05-2020, 11:57 AM
  no HDMI (DP) Output over Dock vuj 17 11,066 06-11-2022, 05:51 AM
Last Post: zltpxqhp69o2
  Ethernet through the dock? Diagon 22 19,755 01-25-2021, 01:05 PM
Last Post: zborgerd
  screen goes blank when I insert pinephone dock, or usb-a to usb-c adaptor rp3 3 3,428 01-12-2021, 05:06 AM
Last Post: rp3
  HDMI on Mobian sundog 2 3,189 09-08-2020, 09:19 AM
Last Post: sundog
