USB-C CC pins are pulled to the GND by AW3512 (VCONN switches) when VCONN is off
It means that you'll have to use software to manually switch from normal charging/device mode and USB OTG mode (e.g. plugging a USB mouse into your phone).
The phone won't be able to detect whether it's plugged into a PC/charger or whether you have some USB device plugged into it that you expect to work.
The fix is to desolder a couple tiny switches that aren't particularly important. I've completed that on my phone, I can confirm it fixes the issue.
As to whether to cancel your order, I suppose that depends on how critical automatically-switching USB OTG support is, and/or your comfortability with desoldering a couple little specks from the motherboard.
RE: USB-C CC pins are pulled to the GND by AW3512 (VCONN switches) when VCONN is off - by Subsentient - 06-15-2020, 10:57 PM
  pine64 keyboard pogo 'no-go' pins --- 3 2,523 04-29-2022, 04:59 AM
Last Post: Humid Stylus
  PP v1.2 VCONN question m4xx3d0ut 0 829 03-18-2022, 12:26 PM
Last Post: m4xx3d0ut
  what are these pins above modem chip? zetabeta 1 1,612 12-13-2021, 04:38 AM
Last Post: kqlnut
  Pogo pins power clarification - reading schematics bokomaru 48 42,858 06-19-2021, 10:46 AM
Last Post: bokomaru
  Is the PinePhone only Pine-device with hardware switches? harrm 1 2,223 01-23-2021, 12:29 AM
  Where are the HW kill switches located? WaldoTheRanger 11 14,469 10-04-2020, 02:23 AM
Last Post: WaldoTheRanger
  Only enable modem when needed with kill switches sokolgeo 2 4,094 09-20-2020, 04:40 AM
Last Post: sokolgeo
  hardware switch wishlist/discussion - switches on the outside? mypine 7 7,420 04-12-2020, 10:40 AM
Last Post: wibble
  Kill switches blicken 2 3,834 02-08-2020, 03:51 PM
Last Post: wibble
  PInephone extra pins hnaguski 2 4,591 11-02-2019, 06:01 PM
Last Post: hnaguski
