07-01-2023, 12:32 AM
Arch Linux - How do I terminate a running app? I assume that if several apps are loaded then perhaps there is not sufficient RAM for the next one to open.
Close running app
07-01-2023, 04:55 AM
07-01-2023, 06:33 AM
(07-01-2023, 04:55 AM)shulamy Wrote:(07-01-2023, 12:32 AM)ionmich Wrote: Arch Linux - How do I terminate a running app? I assume that if several apps are loaded then perhaps there is not sufficient RAM for the next one to open. Thanks, I'll try that.
01-10-2024, 07:33 PM
kde you hit the cross button, couldn't be any easier.
01-10-2024, 08:21 PM
(This post was last modified: 01-10-2024, 08:31 PM by Kevin Kofler.)
Yes, the Plasma Mobile solution is much more discoverable. I understand the wish to save a few pixels of the small screen by removing or narrowing the bottom bar, but I think gestures only is a really poor default because it is not discoverable. If you really want that, Plasma Mobile actually supports that too (since June 2022, about the same time Phosh introduced it too; just go to Settings, Shell, Navigation Panel: Gesture-only Mode), but it is a bad default for unsuspecting users. And in Phosh, they have not even completely eliminated the bottom bar, which is the whole point of gestures-only navigation. And Phosh does not even give you an option, they just force the default design on you, which is why I dislike UIs designed by GNOME developers.
Emulation on Pinephone UBPorts CE Running Arch Linux ARM Plasma Mobile | horme7 | 0 | 1,353 |
12-12-2021, 10:29 PM Last Post: horme7 |
