Severe screen flicker + occasional ghosting | Pinephone Beta edition
Hello all,
I wanted to reach out and see if there is a known solution to my issue.  I have the Pinephone Beta edition, purchased during the summer of 2020.  Since near the beginning, at random intervals, the screen would severely flicker whenever the backlight is >30% or so.  This happens at random intervals regardless of battery or charging status.  I have also noticed occasional ghosting on the display that persists after reboot.  I've reseated the display connector to no avail.
My distro is stock Postmarket, although I suspect this to be a hardware problem (perhaps with the display controller?)
Has anyone else experienced or resolved this issue?
I have seen screen flicker with Manjaro, openSUSE and SFOS.
I see it often, on both my original and the Pro, running all different OSs at different times. I've never been able to correlate it with screen brightness or phase of the moon or anything like that, it just happens, later it won't be happening.
***   Don't be a minion in the (i)droid army   ***
See here for some possible explanations. Unfortunately there seems to be no easy fix in sight.
Mind that one of the common causes for screen flickering is also if the phone wasn't shut down after the previous boot (e.g. it was forced off). The solution for that specific kind of flickering is to shut down the phone properly once (using the shutdown menu or using "poweroff") and then to boot it again.
Does the phone stop flickering when it's plugged in and charging?
  my pinephone melted norayr 6 800 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,072 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 688 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 322 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,764 02-05-2024, 03:17 PM
Last Post: wigan
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 375 12-28-2023, 01:26 PM
Last Post: bedtime
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,590 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,373 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 961 10-23-2023, 02:49 AM
Last Post: Uturn
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,336 10-12-2023, 01:03 PM
Last Post: robthebold
