GPIO Table
I have edit the wiki with table for GPIO
https://wiki.pine64.org/wiki/Quartz64#GPIO_Pins
Can someone please check it? Thanks.
Source: https://wiki.pine64.org/images/3/31/Quar...201215.pdf
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
According to pgwipeout, pin 7 right now is likely to just be a regular GPIO (GPIO0_A0), as he has been unable to actually get CPU_REFCLK_OUT from there. You can try this hypothesis by wiring an LED through a 220 Ohm resistor between it and GND, and then running gpioset 0 0=1 but this probably all depends on your device tree and kernel you're running.
Some more notes on the GPIOs I've written up based on the schematics a while ago:
  • pin 3 (I2C3_SDA_M0): can be pwm, pulled high to 3.3V through 2.2kOhm resistor
  • pin 5 (I2C3_SCL_M0): can be pwm, pulled high to 3.3V through 2.2kOhm resistor
  • pin 12 (UART0_TX): can be pwm
  • pin 14 (UART0_RX): can be pwm
  • pin 18 (SPDIF_OUT): low-pass filtered with cutoff of 220 MHz
I might add those as notes to the wiki table later when I get the time.
It's also important to note that these are the GPIO bus assignments for the Model A. But we can do the wiki formatting distinction when the Model B ever sees the light of day.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  gpio on Quartz64-a jyoung 2 531 02-23-2024, 03:01 PM
Last Post: jyoung
  Lowest possible power consumption on with everything disabled except GPIO inputs? Wookbert 1 1,461 08-19-2022, 03:13 AM
Last Post: Wookbert
