New screen, now cant make calls
Hi all;
I dropped my phone a while back, I got a replacement screen and installed it myself. First time on any phone...
I put it back together and the modem doesn't appear to be working, have reinstalled mobian, I have signal strength, but not registered on the network. Everything else seems to work WiFi is good.
Have tried different sim card, no change, sim works on other phone.
Is there anything I can do to narrow the fault down to software or hardware ?
I guess I must have stuffed the main board somehow when I pulled it apart, but it would be good if I could confirm it.
(03-14-2021, 08:23 AM)bug1 Wrote: Hi all;
If you are showing signal bars double check your carrier and APN settings. They may have changed and you lost voLTE because of the change.
(03-14-2021, 08:36 AM)C0ffeeFreak Wrote: If you are showing signal bars double check your carrier and APN settings. They may have changed and you lost voLTE because of the change.
Im starting to think your right, maybe it was just a coincidence wit hme changing the screen, and its software related.
The previous sim i tried was from the same network provider, so it probably wasnt a good test of the sim. I got a new sim today for a different network, it still doesnt see a network, but it has given me a new list of APNs to choose from, so something is going on, will treat it as software problem, and use command line to find an error message...
Thanks for your reply.
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 415 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,471 10-12-2023, 01:03 PM
Last Post: robthebold
  No calls in or out on beta IsaiahSp 0 712 09-28-2023, 10:44 PM
Last Post: IsaiahSp
  No calls on Pine Phone Beta convergence edition polypode 1 1,218 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Screen dying already? marcih 153 149,028 02-23-2023, 04:14 AM
Last Post: Shatur
  I cannot call or receive calls aka0kuro 6 3,203 01-13-2023, 05:31 PM
Last Post: alaraajavamma
  Screen Replacement Instructions erikkugel 4 3,262 09-07-2022, 11:04 PM
Last Post: RTP
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,740 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 1,811 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 4,127 03-08-2022, 12:25 PM
Last Post: jopple
