Is it possible to get Pinephone electronic components separately?
I want to build a bicycle computer around a phone using the app "IP Bike", with a camera and a custom high powered LED on a rotatable mount, roughly perpendicular to the screen. The form factor / design would be almost entirely unlike a phone, but the phone's components are possibly better suited to this, compared to the available SBCs.
Is this likely to be possible? Either now or in the future?
You can buy almost any of the Pinephone parts in the store, but availability is scarce at the moment because of the general situation of the semiconductor market and making new batches of Pinephones takes up all the supply currently...
https://pine64.com/product-category/smar...46c16e2e66
I see! Thank you. I feel like I should've been able to find that on my own on the store page. Is it likely to be possible to use something like an ArduCAM with the Pinephone mainboard instead of the 5mpx camera listed there, and can I use a screen of my own choice?
While it's certainly possible to adapt other cameras and screens via breakout boards you have to make for the FFC cables to match the pinouts (there's no standard for this really), you also have to make sure all the signal voltage levels work with your new devices (e.g. 1.8V digital interface of the CSI bus, 2.8V analog supply, backlight driver current and voltage for the LCD, LCD MIPI interface, etc.), so it's not a trivial hardware hacking task. And then adapt the devicetree and kernel drivers to support your new devices. So it really comes down how familiar you are with embedded hardware and Linux kernel hacking?
Not familiar at all unfortunately. I've used Linux a bit, and done some other programming, but I'm mostly a CAD guy.
I've made a parallel thread in the A64-LTS sub-forum, because it's possible that meets my needs better; https://forum.pine64.org/showthread.php?tid=13341
I think getting the hardware connected would be the easier task for me, but I'll be in the deep end with the kernel and drivers. I'm guessing that I would be porting those over from a build that supports the hardware as a best case scenario right? Like taking a pi supported device, and the drivers for that and adapting that for Android on the Pineboard?
  my pinephone melted norayr 6 826 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,079 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 707 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 337 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,818 02-05-2024, 03:17 PM
Last Post: wigan
  Components layout scheme squareroot 1 522 12-31-2023, 06:44 AM
Last Post: zetabeta
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,760 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,387 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 990 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,110 08-23-2023, 03:25 AM
Last Post: Kali
