06-26-2016, 05:55 PM
How many mAh does the LCD panel draw from the board?
LCD Installation Walkthrough
06-26-2016, 07:36 PM
06-30-2016, 12:51 AM
(This post was last modified: 06-30-2016, 12:53 AM by nielsnuebel.)
For Mac-User:
Quote:df -h then leave it alone, we’ll need this later on
Quote:df -h
Quote:sudo diskutil unmount /dev/disk2s1 (or the name you obtained above)
Please double check this step, wrong operations may result in a wiped hard disk! Quote:sudo dd bs=1m if=[img_file_path] of=/dev/[sd_name] (You can also drag&drop the .img file on the terminal instead writing the full path)
Quote:sudo diskutil eject /dev/rdisk3 or how your card is named
06-30-2016, 12:54 PM
You can also use ApplePi-Baker. It's free and works very well.
07-01-2016, 07:34 AM
Ok this is probably a very stupid question but this is my first time using electronics of this fashion. It's fairly obvious what orientation the cable needs to be inserted on both ends (metal meeting metal) but when I try to plug it in it refuses. Not sure if it is just a very tight fit or if I am missing something. Is the black piece at the end of each plastic connector a lock mechanism that needs to be removed or lifted before the cable can be plugged in?
07-01-2016, 08:01 AM
(07-01-2016, 07:34 AM)Topgun505 Wrote: Ok this is probably a very stupid question but this is my first time using electronics of this fashion. It's fairly obvious what orientation the cable needs to be inserted on both ends (metal meeting metal) but when I try to plug it in it refuses. Not sure if it is just a very tight fit or if I am missing something. Is the black piece at the end of each plastic connector a lock mechanism that needs to be removed or lifted before the cable can be plugged in? You have to lift up the black piece and then insert the cable and lock the black piece again. Photo by @edinor
07-03-2016, 01:48 PM
Thanks for this topic!
My LCD Touchscreen works really good Best regards Julian
My forum topics:
• Create a WiFi hotspot on Debian 8 • Turn your Pine64 into a music server with mpd • Adjust brightness of LCD on Armbian Desktop with 1 click • My cases for Pine64 (acryl, lego & wood) • Pine 64 - DACH - Facebook page for german-speaking Pine64-fans.
07-04-2016, 06:29 PM
I received my kit on Saturday, but the touch screen I have received also dead. Tried several times connecting it but no luck. Works fine with the HDMI. If I contact the seller would I get e replacement screen?
Sent from my iPad using Tapatalk
07-05-2016, 12:11 AM
(07-04-2016, 06:29 PM)Flyingcom Wrote: I received my kit on Saturday, but the touch screen I have received also dead. Tried several times connecting it but no luck. Works fine with the HDMI. If I contact the seller would I get e replacement screen?read the thread again... you need to download a different image file... (assuming you're using android)...
07-06-2016, 09:26 AM
Has anybody gotten this working with a linux image?
Are there nonstandard drivers I need to install? |
Information & installation of the LCD [GERMAN] | JulianM | 1 | 3,133 |
08-05-2016, 11:21 AM Last Post: tllim |
