Initial OS GUI troubles (log out, black screen, crash screen)
Bug
So I received today my Pinephone64 Manjaro edition. I made the first setup, everything seems fine but few second later I'm log out (screen lock) from this point every time I unlock the phone, I have only few seconds before it automatically lock again.
More concerning : instead of a log off I often get a crash screen. This one :
[Image: 1hGwtZfl.png]
Sometimes it is just a blackscreen.
By using virtual consoles (ctrl + alt + f1) I have been able to force an update with pacman (-Syyu) also I never get any trouble from those consoles, I suspect the problem to be in the desktop environment (if I can call it that way Undecided )
Maybe force reinstall the GUI could do the trick ?
I'd like to fix it without having to reinstall the OS, I do not have a SD card, unless there is a way to reinstall to eMMC from my desktop ?
However, where can I find the log file ?
Thank for your help
That release of Manjaro is very unreliable and I had predicted troubles as you have to endure now.
I suggest NOT to flash the emmc but to buy a micro SDHC card for a few $ and to reflash emmc only when you have found a satisfactory software system.
(IMHO currently there is none at all)
(11-03-2020, 07:59 AM)LinAdmin2 Wrote: That release of Manjaro is very unreliable and I had predicted troubles as you have to endure now.
Do you think a future update of the OS could fix my problems ?
Some day in unknown future the software will be acceptable.
If you enjoy playing around, buy a few sdhc cards and put various images to see the differences.
If you don't enjoy that - just wait ....
  screen brightness Uturn 1 720 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 677 07-07-2023, 09:38 AM
Last Post: Uturn
  Backup and Home Screen Tinkering on Phosh jakfish 0 866 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen timeout makes alarm and timer unusable... Eugo 9 4,065 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,956 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 7,248 09-05-2022, 03:50 PM
Last Post: christev1
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 1,003 07-04-2022, 11:42 AM
Last Post: tuxmain
  How to return to "home screen" hiddenpotato 7 6,335 03-05-2022, 06:21 AM
Last Post: dcinoz
  Manjaro Welcome screen landscape JohanB89 2 2,217 11-12-2021, 01:13 AM
Last Post: acrux
  KDE Plasma Mobile screen scaling Uturn 1 1,838 10-29-2021, 06:59 AM
Last Post: Uturn
