Wiki Apps
I made an app I would like to get on the wiki, how does one go about doing that?
Pine64 wiki or mobian wiki? For Pine64 you _should_ be able to log in with the same credentials as for the forum. For mobian you need to register separately - there's a 'register' link below the username/password fields if you use the login button.
(09-01-2021, 09:42 AM)wibble Wrote: Pine64 wiki or mobian wiki? For Pine64 you _should_ be able to log in with the same credentials as for the forum. For mobian you need to register separately - there's a 'register' link below the username/password fields if you use the login button.
I meant the Mobian wiki, thank you for the info! I don't know how I never noticed that login button!
  New Install, apps start but don't show up on screen?! RT3 2 3,189 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,284 01-15-2025, 08:08 PM
  Keyboard not popping up on QT apps 3x5co 1 3,232 02-08-2024, 11:45 PM
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 2,614 07-17-2022, 10:34 AM
Last Post: 3x5co
  Using lat/lon in GPS/GNSS apps and Messaging biketool 6 9,047 05-04-2022, 11:45 AM
Last Post: wibble
  Mobian wiki and IRC forum sticky? biketool 1 2,827 04-30-2022, 08:24 PM
Last Post: TRS-80
  Apps and SD Card biketool 2 4,557 03-06-2022, 09:47 AM
  Mobian WIki Sidebar Edit biketool 0 1,839 03-06-2022, 01:52 AM
  Reskinning Apps for Mobile biketool 6 8,741 12-05-2021, 02:30 PM
  no access to webdav files (for some apps) jsch 0 2,828 11-13-2021, 09:46 AM
Last Post: jsch
